1 - 1 of 1 Posts
Temp gauge on my 95 c180 went to jus under 100 degrees then went back down to 80 so just htought an air lock, when i got home noticed steam under the bonnet, had a look and notice a patch a water under the engine on closer inspection notice the water on the water pump, one jus above alternator, is this the water pump leaking? do they have two as when i looked for the part noticed that they had a water pump listed for £43 pounds but also a part called water pump - additional, do they have two pumps if so which one is which?
Cheers
Mark
1 - 1 of 1 Posts
