Hello guys
I have a leak coming from the seal rings/hollow screw on the steering rack gear as you can see on the attached pictures. I know that this is not a pretty common issue but your help is much appreciated.
I also want to make a sticky on this DIY too :thumbsup: so This is a good change to help out
The seal rings number is A0249977148 and the hollow screw # is A2109900763 on the epc parts list for steering gear and steering linkage.
I went to a MB dealer and i got the seal rings. So far so good. I'm trying to DIY on this one (i already changed the thermostat by my self thanks to a DIY sticky) but i cannot unscrew the hollow screw and i'm scared to use more strength and damage it. :crybaby2:
Has anyone repaired this leak? How do i unscrew the hollow screw?
Again your help is much appreciated and also this could be a good sticky DIY
