1 - 8 of 8 Posts
1985 380SL
I am in the process of replacing my soft top. Can anyone tell me if there is supposed to be a rubber seal on the latch pin? Seems like I have seen one on some pictures, but can not find what it is called or where I can get one. One did not come in the weather seal kit that I bought when I purchased the top replacement. Thanks in advance.
I recall the long seal tucks around the pin. Mine did not have a separate seal either.
R/C107 Moderator
It should have a round seal. EPC calls it grommet. 107 997 16 81. Try Mercedes or google the part number. https://www.pelicanparts.com/More_Info/1079972781.htm?pn=107-997-27-81-MBZ
You need to get used to using the EPC (Electronic Parts Catalog) especially if you have a Euro version. Here are a couple of online versions https://nemigaparts.com/cat_spares/epc/mercedes/ and https://mercedes.7zap.com/en/eu/fg/car/
Here are pictures of it on hard and soft top
View attachment 2612763 View attachment 2612763 View attachment 2612764
Thanks Rowdie, I just checked my hard top - it is missing the grommet as well.
1985 380SL
I ordered the part suggested and it does not appear to be the correct item. the hole diameter is larger and not completely open. I think this may be a floor drain grommet as the center part has little holes to allow water or something to pass through.
R/C107 Moderator
Picture? Where did you get it? They sent the wrong part. Return it and go to the dealer. That is the correct part number listed here. Verify it yourself using the EPC.
1 - 8 of 8 Posts
