Mercedes 190E 2.0L - 1986(black with grey)
Work in progress...
So, here is the story.
My engine was stopping every one minute, my care taked long time to start when cold(cold start syndrome).
Two months ago I have replaced the fuel pump, return line hoses and fuel filter. There was no improvement.
This time I have bought a brand new vent valve, a fuel pump bracket. The old one was rusted.
I have began the work by disconnecting the main fuel line from the distributor rubber hose. From there I have plugged into
another hose to empty the fuel thank. After that I have taked out the fuel pump relay an connected the fuel pump supply pins to the battery.
Everything worked smooth. Now with the empty fuel tank I have disconnected all fuel lines from the fuel pump, filter and fuel accumulator.
I have taken down the bracket and replaced with the new one, wich I have painted with metal particle paint for better protection agains rust.
After that, I have removed the old vent valve and replaced with the new one.
Cleaned the fuel pipes with a strong compressed air jet.
I have reconnected al lines back, filled up the tank, and turn the ignition.
Big surprise. Everything was the same. The engine was stopping every one and a half minute.
I din't knew what to do anymore. The last solution was to unplug the rubber hose from distributor. There it was a small filter that I have removed.
Triyed to blow trough that, BIG SURPRISE again.
The filter was like a dead rock. I have gone in a more lighted place and noticed that there was a thick black dirt.
I have put the air compressor on that filter and removed al the dirt that was there. Plugged back into the distro, pluged back the fuel line, and I was ancious to turn the ignition.
FANTASTIC, the engine was running like a charm. Like a char. He wad gained the lost power and everything was going smooth.
Another problem was the cold start syndrome.
I have removed the OVP relay and FUEL PUMP RELAY. After that I have removed the relays housings and the surprise was that the pins ware weared out and I had retension them using a clamp.
O2 Sensor problem.
Last time I have worked on my car I have noticed that my O2 sensor was removed from his place, instead, there was a big screw mounted where O2 should be.
I have triyed to remove the screw till I realised that it was welded on the exhaust.
BIG PROBLEM, but I had the answer.
Discussion Starter · #2 ·
I have cutted down that fucking thing. Now I have welded back in thet place a nut that was right for the sensor.
My new ride it's all most complete:
Next:
- wheel bearings,
- a new exhaust system,
- new clutch kit,
- tie rods,
- servo BOX.
Discussion Starter · #7 ·
Next weekend plan.
Hi all.
I have planned a small work on my benz next weekend.
Here is todo list:
- front and rear ball bearings
- dirrection suspension
- tie rods
- side lights
- flex disc
- thermostat
- etc.
eeeh, I better post pictures of the stuff I'm gonna change :).
Well, I will have two days to complete this...
I'll post pictures from the process.
