Today we had the w140 on the lift, we replaced the oil pressure switch, and cleaned the bottom of the engine and actually found the main cause of my oil leak which was the oil level sensor which is located in the oil pan. That little sensor made it look like the upper oil pan was leaking. We found the exact location of the transmission leak and it turns out i need a power steering pump seal kit.
