2002 CL55 AMG, 1993 190E 2.3L, 2004 SLK320 Sport
Sorry if this has been posted before!
Great link for finding out what replacement
lamps we use on our cars? The link below allows you to enter the vehicle
model/year and it gives you the correct info needed.....
OSRAM SYLVANIA - Replacement Guide - Start
Lamp Replacement Guide
1999 MERCEDES-BENZ E-class (With HID (high intensity discharge) headlamps)
Low beam headlamp
HID-D2R
High beam headlamp
H7
H7SU SilverStar Ultra: The brightest and whitest light. Up to 50% brighter, up to 40% more downroad visibility and up to 50% more sideroad visibility.
H7ST SilverStar: The brighter and whiter light. Up to 35% brighter, up to 30% more downroad visibility and up to 35% more sideroad visibility.
H7EB EcoBright - Your Environmental Choice. Save Energy - Save Money. Up to 25% brighter light. CO2 reduced 9 to 21%. Gas savings $2 to $19.
H7XV XtraVision: The brighter light for upgraded performance. Up to 30% brighter light and up to 25% more downroad visibility.
H7CB Cool Blue: The whiter light for style. Up to 25% brighter light and up to 25% more downroad visibility.
Parking light
64132
Front turn signal
1156A
1156ALL SYLVANIA Long Life miniature bulbs perform twice as long as any standard miniature bulb. Designed for durability, lower maintenance and greater safety.
Rear turn signal
1156A
Tail light
5007
5007LL SYLVANIA Long Life miniature bulbs perform twice as long as any standard miniature bulb. Designed for durability, lower maintenance and greater safety.
7225
7225LL SYLVANIA Long Life miniature bulbs perform twice as long as any standard miniature bulb. Designed for durability, lower maintenance and greater safety.
Stop light
7225
7506
7506ST SilverStar: The brighter, whiter signal light. Up to 30% brighter light, up to 20% whiter light and up to 10% farther and wider.
7506LL SYLVANIA Long Life miniature bulbs perform twice as long as any standard miniature bulb. Designed for durability, lower maintenance and greater safety.
High mount stop light
7506
Fog/Driving light
H1
H1ST SilverStar: The brighter and whiter light. Up to 35% brighter, up to 30% more downroad visibility and up to 35% more sideroad visibility.
H1XV XtraVision: The brighter light for upgraded performance. Up to 30% brighter light and up to 25% more downroad visibility.
License plate
6418
6418LL SYLVANIA Long Life miniature bulbs perform twice as long as any standard miniature bulb. Designed for durability, lower maintenance and greater safety.
Back up light
7506
Front sidemarker
2825
2825LL SYLVANIA Long Life miniature bulbs perform twice as long as any standard miniature bulb. Designed for durability, lower maintenance and greater safety.
Rear sidemarker
5007
Glove box
6418
Map light
64132
Dome light
6411
6411LL SYLVANIA Long Life miniature bulbs perform twice as long as any standard miniature bulb. Designed for durability, lower maintenance and greater safety.
Step/Courtesy light
6418
Trunk/Cargo area
6411
2002 AMG E55, 1997 E320
Great post! :thumbsup:
Here is the run down for a 2002 -(I did not check to see of any lights were different from the 1999)
Will save a copy of this in my ar files.
2002 MERCEDES-BENZ E-class (With HID (high intensity discharge) headlamps)
Low beam headlamp
HID-D2R
High beam headlamp
H7
Parking light
64132
Front turn signal
1156A
Rear turn signal
1156A
Tail light
5007
7225
Stop light
7225
7506
Assembly
Fog/Driving light
H1
License plate
6418
Back up light
7506
Front sidemarker
2825
Rear sidemarker
5007
7225
Glove box
6418
Map light
64132
Dome light
6411
Step/Courtesy light
6418
Trunk/Cargo area
6411
____________________________________________________
The applications presented in this replacement guide have been compiled using the best information available from the vehicle manufacturers at the time of your search. This guide is intended for general information purposes only, not to be construed as any type of warrantee as to any particular application. For specific applications the vehicle owner's manual should be consulted.
When two or more lamps are listed for the same application, remove the lamp and check the numerical designation
