1982 Mercedes Benz 240D
I have done research on adjusting the air/fuel ratio but it seems something still isnt right. From what I have read the voltage across the sensor at the x11 connector should very by a volt or two. I am getting readings between 3.8 and 4.5 and nothing more. At first it was over 5 volts and reaked of gasoline from the exhaust. That has deminished a great deal but still has the smell. My O2 sensor voltage is dancing as it should so I know that is doing its job.
The reason I decided to go for this adjustment was I had some consistant power loss. In set intervals the car would drive normal then have a sudden power loss followed by power gain in a set pattern. similar to the duty cycle pattern across the lambda on a scope.
any ideas?
2008 E350 4M, 2016 Audi Allroad, 2019 Audi Q5
Sypherz....could you do me a big favor and tell me the procedure you did to probe the O2 sensor? I am getting some odd readings that I cannot understand. I just want to make sure I am not doing something stupid.
That would be great if you could.
3.8 - 4.5v fluctuating works out to be ~28% which is far too lean. In your case though, your DMM may be reading it inversely which would make more sense....so 72% rich...hence why if you raise the mixture it becomes WAY to rich.
Try leaning out to 5.5v and see how the car feels. Counterclockwise on the mixture unit.
Ill have to find the formula that I used but my calculations put me at ~48%, and the fumes of gas diminishing helped me feel as if that was accurate. Initailly when I was 5+ volts the gas fumes was quite high.
I used a multimeter with the positive in pin 3 and the negative in pin 2. From that reading with the motor hot it was dancing right at ~5 volts, and I judged it as I turned the adjustment screw CCW till I hit the high 3's, low 4's.
I dont remember the O2 reading but I do know it was tolerable at the time. I still have the airbox off so I can redo the measurements if you feel something is still off.
I want to add that I just replaced the spark plugs. The old ones were not the recommended plug and based on the copper hue I am assuming they were too hot as well. It seems to idle better than it did before however the power loss still exists.
I checked the plug wires in the dark and I see no signs of arc. Air filter is new. Fuel filter is questionable.
It always has had some issues starting. Sometimes I have to allow the motor to cycle for nearly 5-10 seconds before start unless I pump the gas pedal. higher RPMs cause the gasoline odor to return.
