On my quest to eliminate my rough idle I decided to replace my ICV. My original unit definitely works to some extent but I was curious to see if a new ICV could smooth out some of the surges. I’ve already done the entire vacuum system, idle control relay, ignition system, fuel distributor, injectors and this was an easier job than overhauling the intake manifold which is the last culprit I can think of.
I bought this beautiful shiny ICV made by LÖWE when I was in Europe which is a direct replacement for my original part A0001411425 - Idle Air Control Valve (IACV) 5351425 fits Mercedes - loeweautomobil.de
I’m fairly sure that this thing just arrived broken and to make matters worse I am now back in South Africa which makes returning it for a replacement a much more complicated procedure.
With my original ICV - Starting from cold it idles at 950 RPM then drops to 700 RPM at 40°C. If I disconnect the ICV then it hits 1450 RPM.
With the new ICV - Starting from cold it idles at 700 RPM. It then rises to 1000 RPM at 40°C and then to 1100 RPM at 80°C. If I disconnect the ICV then it hits 1450 RPM just like before.
I am waiting for a reply from the manufacturer but does anyone know if this could be fixed? I’ve only heard of soaking ICVs in carb cleaner to remove the gunk but there’s surely no gunk on this one. And I guess another question would be is it worth getting this replaced if the aim is to smooth my idle? It looks so pretty though!
