1985 500sel
The valves on my 85 500sel are knoking how can that be fixed. Can they be adjusted or do they have to be replaced.
88 560SEL
Nothing to adjust I'm afraid. The hydro valve lift adjusters are there to take care of the adjustment issue. Knocking valves is usually caused by:
Worn camshaft
Worn valve rockers, or
Worn hydro valve adjusters
Any one of, any combination of, or all three causes will cause knocking.
The valves are "adjustable", you select different sizes of shim pucks based on valve stem height which changes due to wear. Mercedes makes a tool for reading whether the shim is too big or too small. However if they are really making a racket instead of the "ticking" then maybe a valve job should be done first.
Mercedes 420SEL
Yeah sounds like it needs a valve job. But if it's not that bad dont worry about it, it's nothing serious. Mine has been knocking on cold starts for a couple of years, it's no big deal.
1985 500sel
yeah hey thatks for those responces. THE CAR HAS BEEN KNOKING FOR A WHILE BUT IT'S JUST ANOYING TO LISTEN TO THE KNOKING. I'LL LOOK INTO GETTING A VALVE JOB.
