1 - 20 of 25 Posts
2001 SL500
Basically, from a standstill I accelerate very lightly and let go of the gas pedal, engine braking takes place like normal, BUT, if I start accelerating again, slowly or quickly, I get a bang/knock as soon as I press on the gas. It’s loudest from the outside of the car.
There’s a slight jerk accompanying this banging. Anyone know what the hell this is? Sounds like it’s coming from transmission or driveshaft...
1992 Mercedes 300SL R129. 94 S320 Mercedes w140
Is the knock in the rear, transmission area or like it is a broken mount in the engine compartment?
1998 SL500, 1999 ML320
If you decide to replace your engine mounts there is a very detailed instruction writeup from Mercedes. You need to be sure to follow it to avoid radiator and other damage. Also, the rear mount is probably good but I think you should replace it anyhow.
M113 SL500
You know, honestly, you come on here soliciting advice, and it seems like you find reasons to not check things that people suggest. In the end, you end up taking your car in to repair shops to do the inspecting and work for you. Even with the bad luck you've had with some of the repair shops, they're not any worse than asking people to guess at what your issue is over the internet. So, why don't you skip the soliciting guesses step and take it into a shop and get it checked out if you're not going to do it yourself.
2001 SL500
Discussion Starter #13
Ultimately, I’ll have a shop check what people are suspecting.
I never gave a reason not to check anything, I’m just wondering how suspension can be related if the problem is confined to specifically acceleration after engine braking.
I thought this was a forum... Am I not allowed to think/question? Also, please stay on topic when responding to posts.
1989 W124 260E
I t is a must to have this problem looked at on a four poster lift .
And the first item i would look at is this rubber coupling on drive shaft or as some call it prop shaft .
First picture is the start .And final picture is after the noise was ignored .
Outstanding Contributor
R129 500 SL 1991
^^ Plinker. Ditto. 👍
If I am not mistaken that looks like one of those substandard URO flex disks that were being talked about a few years back, and which let go with very little warning?
Could you declare your source of these photos please?
2001 SL500
Discussion Starter #16
First picture is the start .And final picture is after the noise was ignored . View attachment 2626752 View attachment 2626753
Wow that looks horrid. Checking of the rubber coupling has been noted
R129 500 SL 1991
Well said 👍 but I wouldn’t give too much heed when brownhaus is in one of his moods. I am sure he means well. I have profited from some of his more coherent posts on BW. Probably best to ignore the rants though.
Please continue to use and enjoy this great forum.
1996 SL 500
Flex Disk and not from a R129
By your description, it is in the drive line, Flex disc front, center bearing, flex disc back and differential, oil leak ?
94 SL320 98 SL500 99 SL600
Another spot to check is the 4 diagonal braces 2 front and 2 rear I believe they are T55 bolts. those need to be extremely tight. Normally they will clunk when turning at low speed. But I'm betting on control arm bushings. very common on the R129.
1 - 20 of 25 Posts
