Not sure I know the intended behavior of the kickdown switch if you press the accelerstor to the floor to activate the kickdown switch and keep the pedal pressed to the floor. In that scenario I assumed that the car would upshift normally at the proper rpm. But I’m finding that my car holds the gear that the car was kickdowned to, and will only upshift if I lift off of the accelerator just enough to release the kickdown switch.
Is this normal?
I thought i had problems with mine never would kick down .Asked on the forum and i was told to really push it down on to the floor. And it did for me. Go and give it another try .
SuperModerator
Keeping the foot held down so the floor button is depressed should produce redline changes all the way up through the gears.
They're really firm buttons though so it's easy to let of the button without realising and then it's less fun.
thanks all. Then I'll need to do some troubleshooting when I have the time. When I press and hold the accelerator fully to the floor, she will definitely kick down, but then she gets to..5600 or 5700 rpm then either wont rev higher, or the limiter kicks in and it just holds that gear. When I let up off of the accelerator ever so slightly, she will upshift
Someone here suggested ensuring my fuel pump relay is functioning normally. I'll try that route first.
About this Discussion
3 Participants
ianrandom
Mercedes-Benz Forum
Full Forum Listing
