Have a 2004 e55 with keyless go, had to replace the keys, took to dealer got it back everything works perfect except when opening the drivers door it is not unlocking and opening. works fine to lock, and works perfect on all the other doors and trunk, but not on the drivers door. Before taking it back to benz I was wondering it maybe it was not reset properly, and if there is a fix for this?
Thanks,
1994 E320, 1990 300CE Coupe, 1971 280S
Your gonna need a new outer door handle for the drivers door. The button you push to lock the car is on a different circuit then the inductive grip on the inside which is used for unlocking. Sounds like your inductive grip is no good. Easy fix, not sure on cost of handle though.
Sid
Master Certified Mercedes-Benz Technician
Gasoline/Diesel/Hybrid Certified
AIRCON Certified
1994 E320
1990 300CE
WTB 1972 280SE
