1 - 8 of 8 Posts
hello all
guys i turned the car off when tried again to start it the key won't move at all . also tried to unlock the steering but i coulnt.
please help
your ingite control module could be busted...look at your fuse chart and check fuses
because if u cant turn the key at all.(position 2)..the steering will remain locked
Have you tried moving the wheel slightly and trying again? Do it a couple times.
Do you hear the little motor engage? By that I mean the little 'whine' it gives when the key is in?
Mine is picky sometimes. I have to try a couple times sometimes cause she's being tempermental.
thanks guyz for replying
i have tried all you said but i dint check the fuses ,, i will check and see
thanks
Also make sure there is no dirt or debris on the IR lenses of the key and the ignition switch.
1 - 8 of 8 Posts
