1 - 14 of 14 Posts
I’m brand new to The Mercedes world and forum. I just bought a 2003 SL500 with 40K miles. The central locks work, but the key fob will not lock/unlock the doors or open the trunk.
Over 3 days the fob locked the car 3 times and unlocked it once, and the rest of the time:nothing. I did change the battery in the single remote key I got with the car.
1999 slk230
I have the exact same symptoms. Been search for a while and haven’t found anything. You’re the only person that have the same symptoms so far. I was hoping I find something out before resorting to a new key. And even then I’m leaning towards it not working .
1999 slk230
So I finally jump the gun and got a new key made by a local auto locksmith for 200$. New keys remote lock unlock. Alarm, window up/down is now working but via infrared only about a feet away pointing directly at it.
Not sure how far the range of these are supposed to be. If anyone can share that would be great.
2006 clk 350
Sounds like your key was the problem. Glad you got it working again. As far as the remote window up/down function mine works as far as about 5 feet away (If I’m lucky) only while pointing the key at the drivers door handle
1999 slk230
Thanks for that. I didn’t make many attempts so I’ll have to try it again. Also. Doesn’t our car have a radio controlled feature too ? So the remote can work farther without the infrared?
'03 SL55 AMG, '09 Aston Martin, '13 Audi A8, '07 Mini Cooper S
Try putting new batteries in the original key. Check YouTube for a quick and easy way to remove/install batteries (it takes two, I think they are designated 2020 - not the year, but the battery type). Did this to my 'non functioning for lock/unlock key about 3 weeks ago, and now it works perfectly).
Gary
1 - 14 of 14 Posts
