Look in the edge of the door check and you will see a small black plastic cap. Remove cap and insert correct size of allen key and slacken the grub screw to remove that section of the lock. Then do what you need to do on the bench.
Yep - Did that to get it to this point. It's a #3 torxLook in the edge of the door check and you will see a small black plastic cap. Remove cap and insert correct size of allen key and slacken the grub screw to remove that section of the lock. Then do what you need to do on the bench.
Yes - spent a couple hours in the morning watching videos and scouring the web for how-to's. It's not an allen screw, it's a #3 torx. It was accessed and backed out to get me to the point of the pictures yesterday. I also have a service manual. Unfortunately, it doesn't explain how to remove the key for my scenario. I was able to find one person who had their key stuck in the door at a 45* angle and his solution was to tap it with a screwdriver.Wow check the job out first on how to do the job . you dont just jump in and hope for the best look on to youtube and check the videos for the right way to go about this . With the allen screw locked in it will never come out. Only remove the screw a few turns then give it a try .
Previous owner changed out ignition; hence the different key. I'm guessing the key that works all the locks are genuine MB. New ignition or have mine re-keyed plus the price of an additional key (which I need). Haven't looked at pricing for any of that.You need genuine MB keys and locks, not this aftermarket Silca bullcrap. Only genuine MB uses hardened steel parts, and only genuine MB can get you matched keys to your vin# eliminating the need for different keys for keys between ignition and door locks.
Praise Jesus - Thank you. I was expecting an answer like - You have to remove the engine to get to it.The alarm horn should be located behind the right headlight assembly.
Sent from my XT1710-02 using Tapatalk
