I have a 1980 300D, and it doesn't turn off by key, and now the stop switch under the hood doesn't work either. I tried popping off the linkage attached to the injector pump and yanking on it, and that didn't work either. Disconnecting the battery doesn't work. The only way I got it to turn off was by disconnecting the fuel supply line at the clear filter, and then accelerating a little to hurry up the shutdown time. But it still took a good 10 minutes to turn off.
My problem is that I'm in desperate need of a vacuum pump rebuild, but it makes me wonder. Why isn't it turning off with the stop switch/linkage? Is that still somehow because of the vacuum pump? I'm going to order a vac pump rebuild kit (thanks to info from someone on this forum), but until then, is there another way to shut off the engine? I don't think applying vacuum to the vacuum unit on the injection pump works either. I'd appreciate any information anyone can provide, no matter how small, etc.
