1 - 14 of 14 Posts
2014 G550, 2000 SL500, 1995 E320 Cabriolet, 1980 TR8
My 2000 SL500 has recently developed an intermittent issue (now more often that not) where you can lock the car with the key fob but you can't unlock it. The lights flash when you press unlock so the key is transmitting and the IR receiver is receiving. And you can lock/unlock everything with the key in the door or the trunk, so it is not the vacuum pump module itself.
I think the issue may be a bad connection between the IR remote module and the lock/unlock line on the vacuum pump. Does anyone know where the remote module is located on a 2000 so I can inspect the connections?
Thanks!
1999 SL600 | 2001 SL500 (sold)
Same exact boat as you with my 01. For me It seems when the weather is really hot, then unlocking with the fob works, and so does the trunk release( I have to press down on the the trunk lid).
does your central locking button on the center console work for you?
Discussion Starter · #5 ·
I have the opposite issue - it fails when it is hot and sometimes works when it is cold.
Yes, the central locking buttons work as it should so there is nothing wrong with the locking system itself. It is definitely an issue with the interface between the locking system and the RCL module. I just have to find the damn module.
Reactions: sushipaste
Discussion Starter · #6 ·
Well, I've been doing some deep diving on the net and found a couple of bits of somewhat depressing information. First, it appears that the IRCL module is hard coded to the engine ECU and so can't replaced with a used one and maybe not even a new one. Second, it appears the the R129 uses the same single line style vacuum pump at the W124 (which I also have) and that means that if the connection is flaky from the IRCL the locks would work completely or not at all. It also appears, but I have not verified, that the IRCL module is behind the driver's keen panel to the left of the steering wheel. Lastly, the trunk open feature does not work either.
So I conclude that either the IRCL module has failed or there is some sort of fault stored in the IRCL module that is preventing these two functions from working. Bummer.
Does anyone have any other thoughts?
Thanks!
Apparently this easy fix should could make the trunk release work, but only if the trunk releases when pressing down on lid while pressing the fob button
I will be attempting this
Discussion Starter · #8 ·
I bought the OBDII to 38 pin adapter for my iCarSoft for my MBII scanner and was able to access the remote controller and clear an error code which was "left door sensor open or shorted". I then went through the key re-sync procedure and it seems to work at this point. Who knows, just working for now or really fixed . . .
1997 SL320
Mine is entirely different from both of yours dealing with temperature. Mine seems to work only when it’s dark outside, and in day light, I must be aiming from a shadowy place in order to get it to work.
Discussion Starter · #12 ·
Update: The system worked for a while but has now become intermittent with unlocking again. Pressing the trunk button usually does nothing but when it does something, it locks just the passenger door! The behavior is the same with both keys and at all three IR sensors, and there are no additional codes, so I can only conclude that the IRCL module is failing. Bummer because replacement is a dealer-only affair involving huge quantities of Vaseline. Guess I will have to learn to use the key.
Discussion Starter · #13 ·
Just an FYI update, the IRCL for the R129 is NLA so if it stops working altogether I will have a very pretty brick in the driveway. :(
1 - 14 of 14 Posts
