1993 S600 Lorinser
Good day all,
My key fob for my new addition does not lock or unlock the doors. the key in the door method works as does the switch on the dash. I bought new batteries and tried the syncing method found in the manual and still nothing. Am I hooped or is there somehting else I can try?
Incidentally, when holding down the button I can not see a light - not sure if you are supposed to be able to or not.
cheers,
Rob
2014 CLS63S SB
You should see a light. I think once the button has been held down for 2-3 seconds the light should flash. It must have died recently. If it never worked either you didn't get the feature as standard, (which you should on a 600), or it's been doctored.
1993 S600 Lorinser
Thanks gumsie - guess I better do some surgery and see if I can bring it back to life somehow. Otherwise, I guess it is a new FOB.
Is there a fuse that governs the operation of the FOB controlled door locking/unlocking? Just wondering if that might be a step before I tear apart my FOB.
Cheers,
Rob
