2002 Black SL500, 2000 Azure blue SL500, 2005 Silver (A209) CLK500
Ebay item number...153041542713
Seller guarantees it will unlock, lock and start your R129.
Has any SL owner member here bought
this system and installed it?
1993 Sl 500
Thank you!
Moderately subtle
94 E500, 97 500SL
I have one in my '97 and it works fine...
I had to wire it into the lock/unlock switch on the center console, but it wound up being pretty easy to do. I think the manufacturer may be out of business, though, so you'd have to find someone to cut the key blank for you.
1999 SL500 (5.5 AMG)
I heard that if you remove the immobilizer chip from the key Fob, and stick it somewhere near the ignition switch, then you can clone as many key fobs as you like.
It's the damn chip that's the problem, they don't make them anymore.
