hi guys i have been trawling the forum for a couple of weeks maybe someone can help, i stripped out the 3rd brakelight in the boot due to warning on dash, i found 1 of the connectors to be corrouded so im searching for a reasonably priced replacement, i was checking fuses ect in the boot at the left hand side.once i found the fault i realised the key fob was no longer working, after reading a lot of posts i now it seems to be the amplifier. i can open/close doors at close range, have checked batterys ect. what fuse should i check and where is the relay or amp located to check connections? i was trying to fix one problem and made anoyher one are the related? clk 240 avantgarde 2002. thanks in advance
