1963 Unimog 404-S
Anyone out there either have or know where to get a Key and Ignition Switch for a 404? I've tried a couple places (EuroTruck Imp., Expedition Imports) but haven't had much luck.
Or, conversely, I heard mention on here of a way to update it to a newer switch...I'm not concerned with keeping it original...just want to keep it running! Is there info on a conversion?
thanks a ton!
-Ted
Unimogs
Hi Ted,
Not sure who you talked to or if you just couldn't get in touch, but that is a common ignition switch that is on the shelf, new MB. (Yes Pricey, I know)
Expedition Imports Corporation Ignition Switch and Key
A little easier on the pocket book is the 406/416 ignition switch which can be easily wired in.
Expedition Imports Corporation Ignition Switch - 404.0/406/416
If it so happens that you need to change out the 404 ignition switch and the light switch, I would go with the single 406/416 switch which is a savings of close to $400. You will lose your blackout functionality, but keep most everything else. This is slated for a web tutorial when I get a chance.
Cheers,
Scott
Hi Ted,
Cheers,
Scott
Scott...Say it isn't soo! $$$
1963 Unimog 404-S
thanks for the replies, guys. Scott, I think an email just got lost in the ether. No big deal, thanks for the response.
My order will be coming through!
