Just thought I'd let you know I ordered a K&N replacement air filter for my 113 yesterday
, I'll let you all know if I see much improvement once I've installed it!
Benz Bling
Benz Bling
Back in the days when i had road going two stroke bikes (men were men & sheep were worried) the easiest tuning mod was to fit K&N filters with an increase in the main jet to take advantage of the extra air flow through the engine the filters gave you. If you didn't check/change the jetting you ran the risk of putting a hole in a piston.walsi said:I know from the motorcycle side that K&N filters arn't allowed to flow any more air than standard filters, i would think the only advatage would be by fitting an induction kit and doing away with the air box but you then have the issue of noise. I stand to be corrected on this but i know they don't make any difference with bikes and you need to look at different manufactuers if you want increased air flow. If only Carlsberg made air filtetrs
In answer to your question Punjabi, yes I have tried taking a sweeping curve at 70mph in my Vito and thanks to my Koni dampers and H&R lowering springs I came out the other side with nothing more than a huge smile on my face! You want to get yourself some decent suspension matePunjabi said:No disrespect but why would one want to 'boost' the performance of what is basically a functional van totally unsuited for high speed?
Performance 'mods' are beneficial on cars and smaller vans - has anyone tried to stop a 'vito' when travelling at 100mph by braking hard? heh, heh....it don't wanna stop 'cause the factory brakes are bl**dy useless! Ever tried to take a sweeping curve at around 70mph? heh, heh.......it don't wanna turn 'cause the handling/suspension is cr*p!
Accept the fact that these vitos/vianno/**** are functional vehicles meant for transporting people and goods - want some excitment on the road, get yourself an Alfa/Saab/Impreza/Ferrari or the good ole Escort Mexico!
My experiance with K&N filters on the bikes was far better than with foam type filters, which suffered in the wet soon getting saturated and blocked.adamuk said:K&N filter installed in my van. Made no discernible difference at all I am afraid![]()
