1 - 20 of 31 Posts
Guys, I completed this repair in about 30 minutes for both sides. You'll find the gaskets for about $58 shipped from Taiwan. They are unavailable from MB. These are the only ones I could find for sale anywhere online.
Tools needed - Philips head screw driver, utility knife, small flat-headed screw driver, small star headed screwdriver/socket
(Ebay listing title) Rear View Mirror Door Cap Seal Mercedes-Benz W202 W210
(Ebay seller) atpartsonline (Feedback Score Of 677) 99.3% Positive
(Link) Rear View Mirror Door Cap Seal Mercedes-Benz W202 W210: eBay Motors (item 140448698556 end time Oct-03-10 00:28:46 PDT)
Very straightforward:
1) Slide off the mirror covers
2) Three fine-thread Philips screws hold the mirror on the body of the car. Loosen the top and bottom one, but don't remove. Push the mirror assembly toward the rear of the car and remove the bottom inside screw that was obscured when the mirror was in the normal position. Then remove the last two screws. The mirror should now be free other than the wiring harness.
3) Use a small flat-head screwdriver to remove the two wiring harness plugs from the large plug in the mirror assembly. Careful prying will free the two small harness plugs (which feed into the car door). The mirror is now completely free.
4) Remove the small star screw holding the harness plug to the mirror assembly. The mirror is now free in your hand. Carefully cut the old gasket away with a utility knife by making a circle around the wiring harness loom. Then pull the old gasket out.
5) Compare the old gasket with one of the new ones - there is one for each side of the car. The OEMs were glossy/smooth, the repro ones are matte and rough in finish, but look great on the car. There is a "square" cutout molded in the new gasket where the wiring plug/harness is supposed to feed through. I cut that out of the rubber with the utility knife to feed the mirror wiring harness plug and loom through. I actually cut slightly below the square in the new gasket, as the loom plug is slightly larger. Feed it through. Reattach the small star screw to hold the plug to the mirror assembly.
6) I then pressed the gasket on the mirror assembly and screwed in two of the mounting screws through the mirror assembly into the gasket. This snugged the gasket into place. There are reinforced indentions in the new gasket for the screws to pass through - and all lined up very well.
7) Reattach the two small plugs coming out of the car door into the mirror harness plug. Then attach the two visible philips mirror assembly mounting screws to the car body. Once snug, push the mirror assembly toward the back of the car and tighten the hidden inside screw. Then tighten all screws and slide your mirror cover back on.
Done! Sorry for no pix. I got so excited I completely forgot about documenting it. Very easy and I encourage you to do it. The parts took a couple weeks to make it to TX from Taiwan.
Thanks - good info. Mine aren't torn, but they are all cracking.
tomorrow I am changing the led signal of the pass side mirror. I hope that it won't be that complicated. :D
Love it. Ordering these. Mine are very poor. Bothers me to see them. I couldn't find them when I looked a while back
thanks
todd
97 e420
Anybody in the US want to check on a group order to one address.? It can't cost more than a couple of bucks to ship a pair of them within the US? $18 for shipping for every order seems like a bit of a rip. Heck, I'd be willing to repackage and ship them.
Len
It's a rip alright ;) But great idea, Len.
Just beware -- these things stink like no other cheap rubber/plastic product I've ever smelled. Good thing they are airing out all day long.
I sent them a note asking how many I could get for the $18 shipping. If the news is good, I'll let you know. Anyone want in if it works out? I just looked at mine again and they are even worse than I thought. Got to replace them.
Thanks for the info Raymond. I looked but did not see the $9 additional shipping fee. Maybe they will cut some slack if I buy a bunch of them. Still no takers yet though.
I agree with you on the price, but if it's the only game in town and I need to do it, I may have to suck it up. I do have a note in to my dealer parts guy about the parts. I sent him your part numbers and also the link to the Taiwanese parts. It sure looks like those part numbers you gave are only for the 126 chassis though according to the EPC. I'll let you know what I find out.
Here is a photo of the rubber gasket on my mirror. Many of yours probably look as bad.
W210 Moderator
youre right, s. my PDF which yielded a match on the part # included the whole
MB price list.....and not limited to 210 which I thought. so the $10 part was for
earlier year. deleting my post.
this is a very old thread, allow me to revitalize...
from the chatting between raymond and sokoloff, it seems there might be a good pricing on oe seal, isn't it? could you advise what the parts# is?
my e300d is definitely in need of new seals...
I ended up replacing the entire guts to my driver's side mirror. Cost was about $500 from one of our wholesale dealers. Easy job once I figured out how to do it. My mirror spring had broken and been repaired in the past and the self-dimming liquid was leaking out, so I just went all out and fixed it all with the new part. It comes with a new seal. As for the passenger side, I did replace the rubber gasket only on that side. There was an old Mercedes part number on it, but it did not come up as available in the EPC. The gasket came from China/Thailand and must have been new old stock. The rubber wasn't as nice as I would expect from a fresh part, but it was a little better than what I had on there.
W210 Moderator
pair on ebay now for $65 shipped from thailand. the cutouts do not appear to
match the plugs within my mirror but at that point (deep inside) it wouldn't be
something that I would be concerned about. just cut "x' and pull the wire/plug
through and it should be fine.....that is, if you're otherwise okay with this item.
Dear sir
Thanks for your help
Please let me know if these two rubbers fit for my E320 2002 mercedes benz.
Thanks.
Dear sir
Thanks.
Welcome, shahidpour. Please take a moment to click user cp and edit details so you can add your vehicle and location to your profile, it's often useful information when you're seeking assistance.
Assuming you have a W210, then yes, these are the parts you need to replace the mirror seals/gaskets as detailed in this thread. The seller atpartsonline actually sells them a bit cheaper directly through their website than through ebay.
Rear View Mirror Rubber Seal all W202 W210 Sedan 4 –Door Models C180 C220 C240 C280 E200 E230 E280 E320
Hope that helps, good luck.
Dear Sir
Where I can find this two rubber seal cap.
I do have a E320 2002.
Please tell me if these two rubber fit for my car.Thanks.
W210 Moderator
i dont recall ever seeing stand alone replacements for the 00-02 model 210s.
this does not mean they are not out there, but just harder to find. you can try
looking at your existing seal for a part number and take that to your dealer, or
to search the part # on the Web.
I would be appricated if someone tell me where can I order the Rubber gasket for left and right side door Mirror of a E320 2002.Thanks.
1 - 20 of 31 Posts
About this Discussion
14 Participants
raymond-
Mercedes-Benz Forum
Full Forum Listing
