83 300TD/97 E320/98 SL500
With ~79,000 miles. Unfortunately, there is no service booklet, and virtually no maintenance records. What are the standard service intervals? I'm fairly unfamiliar with this car, all I know is that it has the inline 6, and pre-dates FSS.
What I can think of off the top of my head:
Does this engine require valve adjustment?
Oil change interval and viscosity (Los Angeles area)
Transmission service interval
Differential fluid (?)
Coolant flush interval
air/fuel filter
Brake fluid flush interval
Any help is greatly appreciated!
1959 220S cabriolet, 1983 240D original owner, 1999 E300 turbo diesel, 1988 560SL, 2003 SLK320
Good luck with the new car. You need to get yourself a set of owner's manuals. MBUSA carries them at reasonable prices. Call 1-800-FOR-MERC(CEDES) and order them or your dealer can get them for you too. That's got all the info you need plus a whole lot more. If your car predates FSS, then I'm not positive about the folowing, but ny guess is that valves do not need adjusted (haven't had to do that sonce about 1985), coolant is probably 3 years, brake fluid probably every two years. Differential fluid is probably not on the routine service recommendations, although it wouldn't hurt to change it every few years. Any dealer can access for you all of the work every done on that car under warranty. The problem is that all dealers are not willing to give it to you. If you can sweet talk a dealership into giving it to you, it would be a nice item to have so you have an idea of what was done.
Len
SLK320, MKV Jetta TDI, Mini Cooper S, Lincoln Mark LT
Oil change interval and viscosity (Los Angeles area) [10w30 every 5k miles or 3k for more city driving]
Transmission service interval [90K miles]
Differential fluid (?) [90k miles]
Coolant flush interval [every 2 years]
air/fuel filter [every 10K miles]
Brake fluid flush interval [every 2 years]
W211/W210 Estate /W209/W208
Get the Replacement Owners/Service Booklet and then go down to a local dealer and have them run the Vin for Service history..Then fill out the replacent manual..Most service advisors will do it (IF) you tip them
Discussion Starter · #6 ·
Thanks for all your help guys. Turns out the manual was just hiding- I have it now.
It's got the typical W210 problems from what I understand- loose rear view mirror, what I think is a bad blower motor regulator, but all in all, a very nice car.
2003 Obsidian Black E320
Congrats,Ler,good luck with it,I've had mine for almost two years,and outside of a small problem with my rear lighting.i'ts all good. May you be as blessed as I am.....[8D]
