RR Silver Spur MKIV, CLK320 Cabrio, E430T 4Matic
Hello forum, I've just bought a 1994 E280T 5speed Auto and I have 2 major issues that have emerged:
1- My cruise control does not work at all
2-My headlights do not work (low beam). High, fog, stand and indicators work perfectly.
I've checked bulbs and fuses and they are all ok. I've noticed something strange in regards to the parking (stand) lights. When I turn the switch on position 1 and 2, the parking lights work perfectly. If I use the parking mode to turn on either the right or left one only, it doesn't. With these symptoms, could it be that I need to replace the switch?
Thank you very much in advance for all your help. :bowdown::bowdown::bowdown:
Hello forum, well, the headlights issue is resolved. A cable leading to the switch was disconnected.
The cruise control issue was related to another problem that involved the RPM stabilizer that I had to replace. I found a used OEM one for 300€. Benz's dealer was charging me 1'150€! Now my idling RPM is dead stable and my cruise control is working.
