Yeah your right. Definetly a leak but I can't seem to point it out. I did the soap/water method on the top of the shock. Didn't see nothing.
I then went under the car and did the same thing on the pump but couldn't see anything either. BUTTT..you know the plastic pipe on it? I got the new one from the dealership to change it out as the old ones are known for leaks..but I could NOT get one end off from the pump..the side that has a "u" shape from one side..it seems to be glued!
What other places could I or should I look for leaks?? Could it leak from the shock .. From the rubber boot areas from inside the fenders..by pulling the tires off?
Help Benz forum!
Help Benz forum!
