It's the beginning of the month... Have you engaged and disengaged your "Low-Range" in the last month?
Now that our vehicles are getting older, and our weather is getting colder, it's important to keep that system movable in order to prevent seizure. We do this by engaging and briefly using the "Low-Range" function of the transmission once per month.
1.) Place the vehicle in NEUTRAL on a level surface. Put your foot on the brakes to keep the vehicle steady.
2.) Press the "Low-Range" button next to your stereo.
3.) The "Low-Range" light on your dash will illuminate, and stay on solid once the cycle is complete. If the light remains flashing, have your vehicle checked out.
4.) A slight "Thunk" from below your butt is normal when the system engages.
5.) Put the vehicle in DRIVE. Be sure to have a firm foot on your brake when you do, as engagement of the Low-Range setting will significantly increase the amount of torque applied to each wheel.
6.) Drive forward for a few blocks, trying to keep the speed below 20 MPH.
7.) Firmly apply the brake, and shift into "Reverse."
8.) Travel in reverse slowly for 50 - 100 ft, if it is safe to do so.
9.) Firmly apply the brake, and shift back into "Neutral."
10.) Press the "Low Range" button in order to shift back to normal range.
The "Low-Range" light on your dash should extinguish, and you're good for another month.
