Hi i have a 1999 s500 and recently i have a problem with the battery.
But my battery is drained by the cold.
After starting the car i have tested the battery andeverything was fine.
but that is not the problem.
I have bougt a jumpstarter but i have heard crazy stories that it can blow your ECU. Is that true ??
And how can you use the jumpstarter under the hood, i don't see posive place under the hood.
2001 E55 AMG
It HAS to be surge protected,whether it's a power pack or jump leads or you WILL fry your ECU..............On the inner wing there is a little black box with a red cross.
where can i find that black box i have searched everywere but can't find it.
Can i use the jumpstarter on the battery positive and negative connection ?
2001 E55 AMG
I might be getting models mixed up.....if your battery is under the bonnet then there is no box....yes you can use the battery terminals,but remember about the surge protection!!!!
Zotye Auto 1.5T T600 2016
There may not be a connection under the hood on this car, connect to the battery direct but connect negative first. If it causes a surge, then quite a few modules will fry.
