Dear AMG owners,
I recently bought a 2010 C63, however it is an import from Japan.
My navigation is still cruising around in japan while I actually live in UAE.
Is there anybody who knows how to install a new navigation?
I also face problems with the AM and FM frequencies as they are way different here from japan.
Thanks in advance.
You need a CD/DVD from the dealership
Only can get it from Mercedes unless you can find in Ebay maybe from somebody
I can give you mine, buts its for US only
Sent from my SM-G955U using Tapatalk
Hey 95gsrturbo,
Thanks for the reply.
How about the FM frequencies, will the CD/DVD reboot the whole system or is it solely for navigation?
With Fm i think if use your menu options and move to audio then select FM then use the center knob to choose a station
If you press down on the knob a menu should come up that says "Autostore" pick that and it should set itself
unfortunately japanese frequencies only go from 76 to 90MHz so i can't really get any radio stations.
Also just FYI i just got of the phone with the UAE MB dealer and they told me i have to replace the whole COMAND system
I seriously doubt thats true.
Need to do more research.
The command system is just a computer. Its the software that makes it work and thats in the CD/dvd
Call a dealer in Europe or US and see if they give you a different answer. Even better, call mercedes in Germany headquarters and see what they say
Hey 95gsrturbo,
The nav you can fix with the correct region disc, but the radio frequencies are a region specific hardware issue. You’ll need to buy a new head unit to fix the radio issue.
