1 - 13 of 13 Posts
2011 S550
When using a floor jack to put your car on jack stands, do you use the same place as the car jack or somewhere else on the frame? I know it sounds a little silly, but dont want to do any damage. I use the frame on my other cars. Thanx all
Hd
2011 S550
Discussion Starter · #6 ·
i put the jack on the hard "rubber" rectangular pads under the car. that's the jack points for the car.
Vortec...Like these? So you would jack one side at a time to do brakes? So if you use floorjack in the pad holder where do you put jackstand?
Thanks for your time and expertise
Hd
· W201, W212, W221, & W222 Moderator
'84 Euro 500SE, '85 Euro 2.3-16, '51 Euro 170S, '97 Jeep Wrangler Sport, '15 G63 AMG
Hey, those look great! How well do they work?
What's the weight rating on these? And mind sharing where you snagged them?
2011 S550
Discussion Starter · #11 ·
Kinda pricey, but I like em.
Load Rating – Jackpoint Jackstands are rated at 4000 pounds. The industry standard for jack stand load rating is to rate jack stands in pairs. Jackpoint Jackstands are rated to satisfy ANSI standards. According to ANSI standards, a single jack stand from a pair must support one and one half times the total rated load for the pair. That means a single jack stand for a pair rated at 4000 pounds must support 6000 pounds. Jackpoint Jackstands have been physically tested to meet or exceed the ANSI standard.
www.jackpointjackstands.com
Hd
Cool! Thanks.
1 - 13 of 13 Posts
