...indefinitely.
I have a new job starting the 15th of November, and while my commute doubles, I'm also getting a 75% raise over the last, crappy job I had. I still have a hard time believing it, honestly.
After mulling it over for several weeks, I've decided the '95 W124 sedan is in good enough shape, inside and out, to keep for a long while. Plus, it's difficult to argue with no car payments, doors which close with a thunk and 23-25 MPG, in-town.
It's gasoline, but I'm gentle with her, hence the good MPG.
Over the past year, however, I've heard some clunks, front-end rattles, and noticed it really needs front-end/suspension work, especially before I put new tires on it. The left-front Continental is having issues with the tread beginning to separate from the carcass, but it'll do for the trip to the dealer after front-end rebuilding.
Doing some shopping, it looks like $1K will cover 4 new tie rod ends, a center link, control arms (IIRC, these ball joints are welded in, and it'll need bushings, anyway, so I might as well do a simple replacement and save the aggravation), sway bar bushings, idler arm bushings, and a steering damper. Oh, this grand also includes four new KYB struts . I know, I know, everyone argues Bilsteins are the only way to go, but I like the KYB feel, better. Well, I really like how Koni's behave, but I'm not about to drop $700 on shocks/struts for a $3K car.
Is there anything I'm missing? Park Place Mercedes is less than 5 miles away, and they'll likely be my alignment place, though I wish I knew of a good independent shop in SW Fort Worth.
Thanks!
After this, I'm going to do a consumables rebuild on the transmission (piston fixing, clutches, maybe bands, and probably a few seals). With 167K miles, this work should get me to 300K...or more.
Thanks!
