Ok so i tried to figure out vacuum systems, todays lesson vacuum locks...
if i look at the picture of a trunk lock, i can see clearly the broken diaphragms, on both sides, but how do i replace the diaphragms? i have to remove the vac lock from the inner trunk lock and then i have to dismantle the whole vac lock to replace the Diaphragms, then put the vac lock together and then install the vac lock and connect the slider to the trunk lock!? wow and then i will have to pray my lock works? is there an easier way?
and on the 3 picture there is a plug under the softtop storage, what is it for? window heating?
Thanks Judy
Thanks Judy
