1 - 14 of 14 Posts
1990 300SE, 1987 190E 2.3
Seems really low to me. Also, it never gets to 80 and it takes more than 10 minutes for the temp gauge to move when i warm it up in the morning.
W126 420SE & W126 300SE
No, thats way too low. Should be a good bit over 80. Obviously it will take a bit longer in the winter time but I think getting a new thermostat might be a good first step.
That's what I was thinking. Just thought I would ask first. That picture was taken about half an hour after the first start of the day after i got to work.
1988 Mercedes Benz 420SEL 258,000 miles (SOLD) 1991 300se 168,000 miles, ASR 1999 GMC Yukon 192,000
our 300se usually stays very hot which im told is normal, you r lookin way to low
1991 300SEL
Yup, most likely the T-Stat is stuck open, or broken.
I see your 150k on the odometer :thumbsup:
About to turnover that 140k mark over here.. keep on rolling!
78 280S, 81 300SD, 82 300D, 92 300E 2.6, 90 260SE, 94 S280, 10 E300,
My 260SE's temperature usually hovers between 80c and the white line above it.
That is where mine is running, and the wife is complaining of no heat. Car has about 100k on the odo. I do wonder if someone pulled the thermostat to guard against a blown headgasket, but I have not checked.
90 560sec, 90 560sel, 92 500sl, 94 e420, 13 e350
This is about the same on my 560sel, just did not get the chance to check it plus really did not drive the car that much. I do get heat though.
'73 450SL, '83 300CD, '01 E320 4matic
The thermostat is 87C, I believe- mine does not deviate from that unless I'm sitting in traffic for a very long time, or I shut it off and restart it within a short time.
If the line above 80 is 100, then halfway in between 80 and 100 should be 90, mine sits just below halfway between 80 and 100.
Discussion Starter #11
What do you mean by "guard against a blown head gasket"? Is it possible to stop a head gasket leak by pulling the thermostat?
1991 300SE W126 Collector owned, maintained 90k mi
Pulling a Tstat wil not lower the possibility of blowing the gasket. It's important to keep the Tstat in to maintain an "operating window" (temp) for the ECU.
Discussion Starter #13
I only ask because i have not looked yet and i was afraid that if i found no thermostat putting one in could cause the head gasket to start leaking.
Do not think pulling the tstat would prevent a blown headgasket (as the go due to a design defect), unless one was worried about the thermostat sticking and causing the car to overheat. Just listed it as a possibility due to the crazy troubleshooting I have seen on this car.
1 - 14 of 14 Posts
