93 190E 2.6; 82 300 SD Turbo
On my 91 300D.. I'm trying to figure out what caused this rust to develop..
Some black tube fell out of the area as I attacked it with the wire wheel. I think I'm just going to pop-rivet and seal a piece of metal in place. Not enough room to do a nice just of welding.. Once my euro's arrive I'll get on that...
Cruise Control
'87 300TD/'90 300D/'94 Quattro/'89 Vanagon TDI/'01 EV Weekender VR6
The car has a fender liner and oil cooler liner, right?
Yes to both. I removed the fender liner and oil cooler cover to explore the hole and clean it up a bit.
04 odyssey (265k) 1995 E320 wagon (295k)
The inner front of the fender corner has a piece of foam attached to it.
If that piece collects water it will make the fender/fender well rust from inside out.
Somewhat common area of rust.
Very comon rust hole :) The others are: rear subframe front attachement points for rear subframe and engine crossmember. Inspect these carefully.
Take a look under the windscreen washer bottle too...
