2003 Mercedes S55 AMG
Is there any way to get rid of the "egg yolk look" from the the front headlights!!!
Do they sell silvervision bulbs for the headlights to replace the blinker lights. I HATE that yellow look in the front headlights...:(
II kings 920 said:
Yes indeed, Stealth Bulbs are a sponsor on the 300C forum and have applications for all cars including MB, BMW, ect. They specifically address getting rid of the egg yolk. Here is the link. One And Only Genuine Stealth Bulbsâ„¢
Ok Thank you very much.:thumbsup: Has anyone installed these on there S class here? Is it simple?
W221 & Audio Moderator
2013 S550
Replacing the turn signal lights with the headlight unit in place is darned near impossible. I know, I tried. Search the forums for any of the many posts on headlight unit removal (no, you don't have to take the front bumper off). Two such writeups are at http://www.benzworld.org/forums/w22...30-headlights.html?highlight=remove+headlight and http://www.benzworld.org/forums/w22...-level-xenons.html?highlight=remove+headlight but there are others. And be careful - you are working around high voltages for your driving lights. Be certain your light switches are manually off (don't leave in "auto") - and ignition off, key removed.
Replacement of the front side marker lights, if you do that, with clear lenses and silver coated yellow bulbs is simple and straightforward (the lenses are available from Stealth Bulbs as well). See Clear Bumper Lights - MBWorld.org Forums, especially the pics in the links at post #44.
