Check the sticky in the W210 forum. Maybe you can use the same "tool". I made mine from a cheap offset wrench. I don't know about your motor, but my guess it is similar.Pulled like hell still not coming off. Any other suggestions?
Which side is not coming off the side attached to the engine? wrap the wire around your hand and yank. if you still can't find someone strongerPulled like hell still not coming off. Any other suggestions?
No.After much twisting and turning I could only remove 3 of the spark connectors. Is there a secret to detaching them from the plugs?
