1993 Mercedes 190E.
One day, the car as normal started. I drove the car for only 10 minutes. I then parked the car for a few minutes. The car then randomly would not start and engine was not cranking and turning over. The battery connection was fine. When I turn the key over, I could only hear the fan moving. I waited for 1 hour and the car eventually started...... The same issue of the car randomly not starting has been occurring many times this past week.
Can anyone offer any suggestions on possible solutions?
fuel pump relay?
starter motor?
crank position sensor?
85 300SD, 82 euro 500 SEC, 78 450SL
If the engine is not turning over you need to check the voltage to the starter solenoid with the key in the start position. Also check the voltage from the battery at the starter motor -- very large battery cable.
