My son is getting licensed soon and I'm thinking about resurrecting my 2000 ML320 that has been sitting for over a year. Everything seems to run well except for the shifter gets stuck in drive or neutral. I have to turn off the vehicle to shift to reverse or park. After she drives 10 miles or so, the problem mostly goes away...but then comes back after she cools down. I don't think anything has ever been spilled in the shifter...but you never know. I just completed a transmission service (new filter, fluid and electrical connector). I'm going to clean the EGR tube and if necessary replace the EGR valve. But, there are so many codes. What do you all think. We purchase the car new and she's been a good girl for 250,000 miles. Here are the codes from my Au7tel MaxiDiag Elite scanner:
ETC – Electronic Transmission Module
Fault Code #1 Code No. 130 Stored
CAN communication with control unit N15/5 (Electronic selector lever module control unit) is sporadically disturbed.
Fault Code #2 Code No. 135 Stored
CAN communication with the engine system is sporadically disturbed.
ESM – Electronic Selector Module
Fault Code #1 Code No. P1856 Stored
Selector lever position detection has failed.
ME2 – SFI Motor Electronics Module
Fault Code #1 Code No. P0400 Current (POSSIBLE FIX – CLEAN EGR TUBE AND BOTH EGR VALVES)
Exhaust gas recirculation: malfunction (function chain)
Fault Code #2 Code No. P1999 Stored & Current
Please refer to vehicle service manual!
ETS Electronic Traction Control Module
Fault Code #1 Code No. C1140 Stored
Unknown fault code
Fault Code #2 Code No. C1141 Stored
Unknown fault code
Fault Code #3 Code No. C1022 Stored
Unknown fault code
BAS – Brake Assist Module
Fault Code #1 Code No. C1202 Stored
A7/7s1 (BAS release switch) : Plausibility
Fault Code #2 Code No. C1207 Stored
S9/1 (Stop lamp switch) : Plausibility
AAM – All Activity Module
Fault Code #1 Code No. B1716 Stored
The ATA interior motion protection/inclination sensor in component N41 (Trip computer (TRIP) control module) is faulty.
Fault Code #2 Code No. B1040-005 Stored
Can Bus: Fault in communication: N10/1 (Extended activity module (EAM))
EAM – Extended Activity Module
Fault Code #1 Code No. B1040 Stored
Fault in CAN communication with control unit MR engine control.
Unknown fault code
Unknown fault code
Unknown fault code
