1 - 8 of 8 Posts
1998 E320
So after fixing the electrical gremlins, we discovered the evaporator is bad.
Indie guy is giving a quote of 1300 based on the part and 14 hours labor.
Is a 98 e320 worth putting that kind of money into?
It depends on how long you plan to keep the car.
From your numbers, it's about $3K total ($100/hour labor) to fix.
$3K divides by the number of days to keep the car will help you decide.
Outstanding Contributor W221 Moderator
2010 E350 P1/P2, 2008 S550 Designo, 2002 ML320
It's all about the miles left on the car, really. If you would drive the car another 5 years/60k miles, then sure it is worth it. If you don't like the car and don't mind having a payment or shelling out 10k for a new car (with new, yet unknown problems) then sell it. No one in my neck of the woods will buy a car without working A/C, but perhaps you won't have that problem?
I had small and intermittent leak for years that I concluded has to be evaporator and in desperation put sealer into the system. That was last year and I did not add refrigerant since.
No offense, but $1500 car is not worth $3000 repair. Unless you have the car in pristine condition and are hoping they become collectible.
On W210 it is not uncommon for a leak at the expansion valve to be misdiagnosed as a evaporator leak. The W210 evaporator was not a wholesale problem like earlier 320's.
Expansion valve leaks stay steady are are low-medium - a evaporator leak gets worse over time and ultimately is like a screen door - everything "poof".
Not saying yours is one way or another - keep the beat !
1 - 8 of 8 Posts
