Hi all i finally got a chance yesterday to change my tranny oll/filter/pressure regulator spring/transmission connector/pan gaskit/TC drain plug & gaskit.
The old atf was very dirty it was like a slush in there. I cleaned up the pan very nicely and installed everything back. I checked the atf level at 79C and it was between the 80c mark on the dipstick...everything was all right untill i decided to recheck the atf today and found that the level was very low
after checking it a few times i decided to take a look under thecar and turns out that the drain plug for the transmission pan is leaking very badly
Ill be picking up a new drain plug and gaskit for the transmission oil pan first thing in the morning and just wondering if it's ok to drain the atf into a clean pan and then reuse it after installing the new drain plug/gaskit??
I took pics for here and will be posting them later tonight.
I'd greatly appreciate it if someone can let me know if i am ok to reuse the atf and also if someone has the part # for a 97 e320 transmission drain plug and gaskit.
Thanks guys.
Cheers
Thanks guys.
Cheers
