Hello, My buddies '72 220D 4-speed is showing signs of retarded IP timing so, after searching around here, I made him a offset 13mm wrench and last night we tried turning the pump a little towards the engine. First thing we noticed is that the bottom nut was missing so we really did not need the offset wrench. Also the other two bolts on top were loose enough to turn by hand. My first thought was "hey this is going to be easy" but that went away when we were unable to rotate the pump at all even when it was loose enough to be moved 1/8" away from the mount.
His car is some sort of grey market import that has the IP with the "oel" cap to fill it's separate sump on the back of it so maybe it's not supposed to rotate. Any ideas how to advance the timing of this pump? I realize it won't just flop about like a loose distributor might but we put enough, I think, force on it to move it a little if it was ready to.
TIA, John..........
TIA, John..........
