Hello all, been using your guidance and help for the past 3 months on my new to me 98 E300 W210.025 model, thought it was time to share some pictures. I bought the car in late December and have been working hard on it ever since. The good when I bought was, paint, interior was 7 or 8 of 10, motor and tranny appeared to be in good order with relatively clear fuel lines, no gross leaks and started up quickly and smoothly. Ca car all its life so no rust, clean and dry underneath. The bad, not sure where to start let's just say many things that all of you have helped me repair, and I'm not done yet. Over all she's getting there, avg 28.5-30.5 mpg so far, ran 3-5 tanks of diesel and 2 tank fulls of bio diesel. Some of the work completed:
Suspension
Front - Sway bar bushings
L Control arm bushings
Shocks
Springs (Eibach)
Shock mounts
#5 pads front
#2 pads rear
E430 17 x 8 wheels
235/45/17 tires
Rear
- Sub-frame bushings (kicked my arse, not complete yet)
- Control arm bushings
- 4 suspension arms
- Adjustable camber arms
Brakes
- Rotors
- Pads
- Brake lines
- ABS/ETS/BAS light Issue
- ABS pump (not did fix problem)
- K40 relay (not did fix problem)
- Brake switch (not did fix problem)
- SAM module (fixed problem)
Motor
- Fuel filter
- Transmission filter / fluid
- Motor mounts (drivers needed)
- Air filter
- Purple Ice (radiator)
- Coolant (ZerexG05)
- Thermostat
- Differential fluid
- Little shock tensioner
Other
- Drivers side window regulator and motor replaced
- Passenger side window in-op, cleaned switches now works
- Cabin filter
- Coco mats
- New fog lamp, parking lamps
- cabin filters
- hood shocks
Still to do:
- I have both heated and multi-contour seats - both are in op as of today
- stereo volume is broken, goes to level 310 volume when turned one time
- sun roof cover is off track, dont want to move sun roof for fear it will open and not shut!
Before and after.
Suspension
Shocks
Springs (Eibach)
Shock mounts
#5 pads front
#2 pads rear
E430 17 x 8 wheels
235/45/17 tires
Rear
- 4 suspension arms
Brakes
- Rotors
- Pads
- Brake lines
Motor
- Fuel filter
- Air filter
- Thermostat
Other
- Cabin filter
- Coco mats
- cabin filters
- hood shocks
Still to do:
Before and after.
