Hey Benzers,
I picked up a 1985 380SL with (115k miles) and because my normal bent is toward FORDS I have quite a few questions. I had a non-Merc Mechanic check the car out prior to purchase and he noted a few expensive repairs.
The first is the replacement of a leaking Oil Pan Gasket. Parts-$55.00 Labor-$1480.00 Ouch. Reasonable? Why (not snide just curious)
Replace "Secondary Air Injection Pump" Parts-$695.00 Labor-$350.00
Reasonable? I'm a carburator man in a FI world, is this real?
For these two repairs I can put a new small block together... Ok OK my wife loves the car and I love her so help me solve this!
Outstanding Contributor Always Remembered RI
Welcome to Benzworld. Please complete your profile as this will help members give you the most accurate answer to your questions. Location is also important when we need to help you find parts etc. This forum is for introductions only and all questions should be posted on the appropriate sub forum for your car.
To edit your profile simply click on quick links “edit profile” (quick links is top Right of the page)
At the bottom of the page you will find forum jump, click on this and view all the available sub forums and there you will find the technical forum for your car.
For FAQ see Benzworld help here:
http://www.benzworld.org/forums/faq.php?faq=vb3_board_usage#faq_vb3_thread_display
Benzworld help is for general enquires and all technical questions should be posted on the specific forum for your car. If you are not sure which forum it should be on then please ask me and I will give you a link.
Regards
