1 - 10 of 10 Posts
i was told that i had to run an intertube in my new 39.5x13.5x20s irock swampers. does any body know diffrent??:surrender:
I have seen plenty of mogs with the tires mounted tubeless, on 404 and 406 style rims. If you do use tubes, make sure you get radial tubes. I was told that radial tires will chew up tubes meant for bias ply tires.
It may have something to do with the type of tire you are using. In my experiences with Michelin 20" XL XZL XML tires, I have been told that there are 2 types of beads, a military and a civilian style. If memory serves me right, I think the main difference is in the angle of the bead in relation to the rim. One might be 5 degrees, and one might be 20. (no idea if those figures are right, just pulling numbers out of my head to make a point) I would assume that the Swampers have a civilian style bead and perhaps the Mog's use a military style bead on their wheels. I would mount one up and see if it seals up nice and tight.
BenzWorld UNIMOG statesman
if those are beadlocks on your mog.. heck no you dont need a tube:rolleyes: from what I understand about it.
Granted though several spare tubes is a heck lot easier to carry around than several spare radial tires.
Interesting, before I mounted my XLs I spoke with an engineer from Michelin. He asked me to send him several pics and measurements of the wheels I wanted to use, but made no mention of the tires. I just said 15.5-20 XL and that was it. FWIW, he told me it was not the ideal seating match, but that it would work and be safe. I do keep loosing the bead on one wheel (PITA) and if Greg doesn't get a line on bolt together wheels I'll call Staun.
bead locks
well the bead locks in those photos are fake beadlocks a buddy had them in his shop and told me to put them on for a joke (mog bling) HEE HEE. they are stock rims. thanks for the responce.
the bling will be comming off when the new rubber goes on. FLAT BLACK:thumbsup:
Riveted rims?
Are the rims themselves airtight? Perhaps riveted together and not welded? I have been looking at those tires myself, let me know how they go. Did you go for the radial or bias ply version?
i belive that they are welded i went for the bias ply for more side wall protection. way more dirt and roc than street. and with a top speed of 46 the bias should be just fine.:thumbsup:
I just put the 39.5x13.5/20" Irok bias ply's on my stock 404 rims. The tire shop didn't seem to think that it would be a problem at all not running tubes. I told them to put bead sealer goop on them just as an added measure. I also had them put a bag of balancing beads inside each wheel just for the hell of it.
1 - 10 of 10 Posts
