Interpret Balance Shaft Sprocket Engine Serial # for 2006 & Later Gasoline Only?
331808 Views 929 Replies 253 Participants Last post by  CetiAlpha5
As some of you know, I just recently bought my 2008 e300 which has the M272 engine. To some dismay, I've read up about the defective balance shaft sprocket issue and how expensive it is to repair. I understand that vehicles with the M272 engines "up to Serial No. 2729..30 468993" (that's the way it's written) are affected and that after that they used a hardened material for the sprocket. From my readings I thought that the affected engines were mostly earlier M272's up to 2007 or so and hoped I was safe. The dealer just told me my engine serial number is 2729..44 307732. SO, am I looking at the ending 6 digits or do I look at the last 8 digits? Seems to me I'm either way over (and safe) or way under (and concerned). Can anyone interpret?? Thanks . . .
1 - 20 of 930 Posts
Last 8 digits, your vehicle is equipped with modified part(s).
Reactions: 2
My engine number is 272964 30 623565. Am I OK?
Reactions: 1
Thanks Konigstiger, I'm REALLY pleased that I won't have to worry about sprocket problems! :) :) :) At the same time I'm almost concerned that the mechanic gave me the wrong number . . . how come Rolex11 has 2 extra digits after the 2729, compared to mine?
Your # is incomplete. One option is to enter VIN, click datacard and check engine # here ?????? if not recognized PM VIN and I will check.
Reactions: 1
M272 Engine Up to Serial No. 2729..30 468993 or M273 Engine Up to Serial No. 2739..30 088611 the material for the balance shaft sprocket and the timing chain guide wheel (idler) was modified on engines past these serial numbers.
Can somebody tell me if this car may have the balance shaft issue?
Vin# WDBUF56J56A979397
Thanks in advance!
Can somebody tell me if this car may have the balance shaft issue? Vin# WDBUF56J56A979397
M272 engine (350) # is 30 376901 and qualifies for replacement.
M272 en
Im new to all this can you explain a little more? So it has the problem, but what'd oes qualify for replacement mean if its out of warranty?
Plan of getting an '06 CLS350, does this engine A272010434480 fall in the category for replacement?the car is spec well but not sure it is a CGI engine also.
I believe my engine falls within this category. Is the replacement covered if you are not under cpo warranty any longer? What exactly needs to happen in order to get a replacement? Can I just bring in a TSB?
I would think you have to have some evidence of failure first. Not all of the cars within the range of being affected fail. Stats that I have heard on that vary from 5% to around 15%, and generally the failure is going to be prior to around 50K miles. In my case, my CEL came on and the failure was evident from the codes.
Cost of repair varies as well. If you are out of warranty, you may still be able to get MB to contribute to the cost for good will sake. It helps if you have been routinely serviced by the dealer, etc. Repair can be pricey. Figures I have heard range from $1500 to $5500.
I wish I could figure out how to use that site. Would a good Samaritan who know how to use it, please verify for me? My VIN is WDBUH87X48B221952.
WDBUH87X48B221952
You are fine your engine # is 272972 30 722742 and it is fitted with modified balance shaft.
Help
So I just backed into my driveway and Im sitting with the car idling. I hear a big POP! and my car drops like I have Hydraulics!! I come out and I see the driver side front end has dropped. Does this related to this blog? Does my engine qualify? Is there a statue of limitations to when MB will fix this issue for me?
my vin is:
03 Mercedes B E320 WDBUF65J63A234998
thanks for any help!!
The soft balance shaft relates to the 3.5l engine, your's is a 3.2 l which at one time did have a recall on the balance shaft but I believe that was in the w210 days.
Do you have airmatic?
I dont believe I have an airmatic.... Im going to call the dealer tomorrow and find out some more. Thanks for your help..
List of effected years and models
Checked about a dozen VINs on 2005-2007 E350 wagons for sales east of the Mississippi. All fall into found thee soft balance shaft engine numbers. Glad you guys had this info. I'm sure w/o it would have wound up with a wagon with a soft shaft and eventually the hard shaft from my local MB service center.
Since I dont want a car payment and maintenance bills the search is on for a 2004 E320 wagon.
List of effected models I found on a class action lawsuit filed against MB.
The Mercedes M272 engine is reportedly installed on the following Mercedes Benz vehicles:
Model Years 2004, 2005, 2006, 2007, 2008, 2009, 2010:
Mercedes Benz C 230
Mercedes Benz SLK 350
Mercedes Benz CLS 350
Mercedes Benz E 230
Model Years 2005, 2006, 2007, 2008, 2009, 2010:
Mercedes Benz CLS 280
Mercedes Benz CLK 280
Mercedes Benz C 280
Mercedes Benz E 280
Mercedes Benz SL 280
Mercedes Benz C 350
Mercedes Benz E 350
Mercedes Benz S 350
Mercedes Benz SL 350
Mercedes Benz Viano
Model Years 2006, 2007, 2008, 2009, 2010:
Mercedes Benz R 280
Mercedes Benz R 350
Mercedes Benz ML 250
Mercedes Benz Sprinter
Model Years 2007, 2008, 2009, 2010:
Mercedes Benz S 280
Model Years 2008, 2009, 2010:
Mercedes Benz CLC 230
Mercedes Benz CLC 350
The Mercedes M273 engine is reportedly equipped on the following Mercedes Benz vehicles:
Model Year 2006:
Mercedes Benz E 500 and E 550
Mercedes Benz CL 500 and CL 550
Mercedes Benz CLS 500 and CLS 550
Mercedes Benz GL 500 and GL 550
Model Year 2007:
Mercedes Benz GL 450
Mercedes Benz S 450
Mercedes Benz ML 450
Model Year 2008:
Mercedes Benz ML 500 and ML 550
Model Years 2006 and 2009:
Mercedes Benz CLK 500 and CLK 550
Reactions: 1
How about 272972-31-139394 (a 2009 built in 2008) ?
THNX
How about 272972-31-139394 (a 2009 built in 2008)? THNX
You're fine.
1 - 20 of 930 Posts
