1 - 17 of 17 Posts
A few days ago I purcchased my first MB, a 2007 C230 Sport Black on Black with only 20,550 miles:D. I love everything about this car except for the interior noise level:eek:. I expected a Mercedes to be very quite but even though it rides very smooth you can really hear the roar of the tires on the highway. I also have a 2002 Toyato Camery and I think the interior noise level is quiter in it than the Mercedes. Is this common for this model car or could there br some other problem causing the high noise:confused:.
300CE-24, W204 C220 CDI, W210 E55 AMG, W124 300TE, W163 ML270 CDI
You bought the sport pack, so its equipped with a sport orientated suspension set up, sports tires and I think that should mean you have a grille emblem instead of the standing emblem. The Noise will (mostly) depend on the tires installed, I believe depending on the country, you get different tires which should deliver same or similar levels of performance. Its also possible that the tires have been changed by the original owner.
Take a look at your tires, go to a tire shop and try some out, better yet go for a more expensive brand and you WILL be rewarded.
I live in the southern USA and the current tires are Michelin Pilot Primacy front 225/45 R17 91W rear 245/40 R17 91W. I also thought it may have been the tires but these appear to be fairly expensive low profile tires and there in very good condition. Has anyone else had A simular issue?
The Primacy is supposed to be a 'reduced noise' sports tire, but it doesn't seem to be the case. Try the BF Goodrich g-Force Sport, they are good performance tires, they should be in your size. I don't know if you can get them there you would have to check that.
Other tires you might want to look at are the Michelin Pilot Sport - The C220 I have rides on these, the noise control is quite good.
All I can say is, before splashing money on a new set of tires, try and determine why there is such loud noise from the tires, they aren't the quietest tires in the market, even for a sport tire but if I were you, I would shop around for an expert's opinion (although they may try to sway you into a purchase with the wrong or misleading information)
The tire shop I go to lets me test the tires if I am seriously considering between a few. I don't know if you could be so lucky though.
Hope that helps. IMO 80% of the roar is due to the tires, the 15% would be road surface and 5% to suspension geometry. Please correct me if I'm wrong.
1993 190E 2.6, 1990 300SEL, 1992 300SE, 1992 400E, 1987 190E 2.6 murdered by my brother.
The Michelin Primacy MXV4 is their all season touring tire so the performance is not really there. I dont think they made a Pilot Primacy. Try the Pilot PE2. Very quite and handles awesome in wet and dry weather. Problem is with high performance tires is that they wear down quickly and when they are worn down, you will hear a loud rumbling noise.
If you want high performance you can try Bridgestone Serenitys. They are quiet and last a very long time and also perform very well. Im running that on my S class and its very quiet. I just changed to Michelin Primacy MXV4s on my 190E 2.6 and it is much much quieter than the Bridgestone Potenza Pole Position RE960s. They got quite loud after 5000 miles. I got 29,000 miles out of them, but the ride was quiet harsh and the rumbling noise drove me nuts! I did the Las Vegas to San Francisco trip with them for 14 times. The noise is definitely stressful during the trip. I had Michelins before and now am back to using them. Check out Tirerack.com. Lots of tires to choose from and people rate them too. Remember your Mercedes is a heavy car so you need to check the load rating on the tire to make sure it can support it. 91 and higher is better.
Tire Noise
We bought a new 2007 E350 - our first Mercedes. The car seemed quiet - the doors shut like bank vault BUT the road noise!!
At low speeds around the neighborhood the car is silent. On the highway you have to turn the radio up to hear well. I determined it is the tires!
I an disappointed with the car for this. The car is 31/2 years old and has 58,000 miles on it. The tire noise has been there since the first day.
Perhaps this is an incentive to move up to the S class. Of course that is out of the question - too expensive.
Our next car may very well not be a Mercedes.
Zotye Auto 1.5T T600 2016
Around 95% of road noise complaints we get are tyre related. That is not only the C Class.
You determined it was the tires as the culprits of the road noise, yet you blame the car? Unfortunately Mercedes are at the top in terms of NVH (Noise, Vibration, Harshness) and you will be very hard pressed to find otherwise.
Might be a good time to invest in new tires and perhaps sound deadening/insulation materials. It'll significantly cut down on road and tire noise as well as help the sound system perform better.
My tires are Pilot Primacy's and they appear to have about half the tread left on them. As far as deadening insulation I would think Mercedes took care of that.
I think I will start checking with tire dealers in this area and try to find some new rubber minus the roar. Since I've only had the car for a week maybe the dealership I bought it from will give me some help.
Thanks for all the suggestions guy's you've been helpful.
I love my C230 and If I can get rid of the tire roar I'll love it even more.
It seemed like my interior noise level increased when I switched tires from Continental ProContacts to BF Goodrich Traction T/A. I did so because the Contis (OE in my case) wore out in less than 20,000 miles. Also the ride is now harsher. If I had to do it again I would look closely at Michelins and the better grades of Continentals.
I agree 1000%. My E430s got different brands of tires on them, one is more noisy than the other on the same road.
The OE Michelin's PS2's on my 05 got really loud and rough when at the end of their service life. I didn't have any complaints regarding noise when the tires were new. Remember you've got a sport tuned suspension and sport tires. Maybe the c240/c280 would've been a better choice?
A cheap tire alternative are falken 912's. About half the cost of michelin's and a lot of tire for the money. Not noisier IMO.
or see if other similar models have same noise. go to used car lots or ride someone's for sale.
once my buddy bought a 560sel, they seller told us is tires noise, it turned out to be the tranny, we changed tires and it sounded no difference.
was there any bearing noise, rear end?
2000 Designo SLK-05 C230WK-05 E320CDi-2010 GLK 350
The Pilot Primacy's get louder as they wear. If you have worn down to 50% of the original tread depth the tires are about as loud as they can get provided you don't have any unusual tread wear patterns developing.
I would guess that they are probably a lot louder now than they were when new.
The Conti's are a lot quieter but I have never had a Conti wear out because they seem to develop tread separations before the tire wears down to the tread wear bars.
When the tires on my C230 wore out I replaced them with another set of Pilot Primacy's and the difference in noise was really apparent. Now that the tires are showing some wear the noise seems to be coming back as well.
When I was shopping for new tires I did get to try on a set of Generals. They were louder new than my worn Pilot Primacy's. The more aggressive tread patterns on the high performance tires is the reason for all the noise in most cases.
Actually Mercedes has the class and noise level is very high quality but In my choice, Mercedes-Benz has unveiled "new-generation" Viano and Vito models. The Viano is a luxurious mega-people mover with loads of space and creature comforts for passengers.
______________
Search Craigslist
1 - 17 of 17 Posts
