Hello Board
I have an issue with the interior blower control.
Had a non-functioning blower motor.
Troubleshooting made it clear that the control panel sends from about 0.5 volts to about 5 volts to the controller. the motor will run off an external power supply.
Changed the controller and the issue seemed to be resolved.
However when the car has been sitting unused for a day or two, the blower will not run.
I have found out that if i unplug the controller, starts the car and then plug the controller back on, the blower works perfectly and responds to the different settings from the controlpanel.
Do i have a defective controlpanel or what??
Regards Mads from Denmark
Hi Mads.Check the fuse f35 housing(?),engine´s right side.Poor power connection,perhaps.Or the regulator at the bottom of a blower.
Hi thank you for replying. I can make the ac blower work perfectly as long as the controller is unplugged when i start the car. When the car is running, i can plug in the controller and the blower works fine until the car has been shut for a day or two.
