1 - 1 of 1 Posts
The speedo and rev counter needles jittered, even with the ignition key removed. They would not give a reading when driving, instead jittering at their zero positions. The only warning lights which came on were the ignition and srs lights. The mileomenter and oddometer stuck, as did the clock. Probably the beginning of the ic problem highlighted previously by Guru. However I found that removing fuse 9 under the column and then putting same back in reset the panel and everything worked as normal. It has happened twice in the past month. This tip may help others.
1 - 1 of 1 Posts
