'83 300CD, '11 Ford Flex Limited, '96 Ford F-350 PSD
LED kits are available and worth it.
1985 300CD Turbo coupe, 2006 E320 CDI sedan
Don't even know if there's a LED equivalent. The instrument cluster backlighting and indicators take push-in type Euro-lamps. I use Sylvania 2721 (W1.2W)
//greg//
81' 300SD, 82' 300D
TURN OFF YOUR CAPS LOCK KEY!
I used LEDs once throughout my 300D. Given my experience with them, I say stick with incandescent. Most of the bulbs I purchased didn't last any longer than incandescent.
'83 300D
Instrument cluster illumination uses 3w 2821 bulbs, the indicator/warning lights use the smaller 2721 bulbs. Here's a list of lightbulbs used on a w123:
http://www.benzworld.org/forums/w123-e-ce-d-cd-td/1416673-w123-bulbs.html
Can also be found in the Online Tech Links Thread sticky at the top of the forum.
As for LED replacements, I'm not entirely thrilled with the "plug-n-play" solution for this so far. May modify a cluster with something more direct and dispose of the light tunnels.
89 300CE, 62 220SEb
I just ordered bulbs for replacement of the cluster as well as the interior lights. ledlight.com was my source. I cross referenced the LED's with the Sylvania bulbs on their site. I'll keep you posted.
Here is a post that will help: http://www.benzworld.org/forums/w123-e-ce-d-cd-td/1416673-w123-bulbs.html
The bulbs I ordered are for my '85 wagon. Check your bulbs' physical size and order accordingly.
