V 220 CDI Trend
The lower right hand side of the LCD guages on my V 220 CDI instrument cluster has darkened behind the time/temp gauge. The distance/trip reading is OK.
Does anyone know if the rear lighting is replacable, bulb or LED ?
Also how is the instrument cluster removed, does the whole dash trim need to be removed to get to it?
There are bulbs behind the display, on my vito (which I'm sure is the same) you should see two caps which look like screwheads, turn them 90 degrees & pop them out, behind these caps are screws, undo them, & pull out the console.
V280, 1998, Metallic Black Paintwork, 7 Captain Leather Seats.... ready for pimpin
replace instrument cluster bulb
Does anyone know what ref number these bulbs are????
